UH60sSuck
UH60sSuck's Avatar
04.16.2008, 10:56 PM
Do you need a hug? You seem a lil grumpy, lol
Lonewolf039
Lonewolf039's Avatar
04.16.2008, 11:09 PM
That looks pretty cool- a nice drop-in unit/assembly. I wander if Mike could do somethig like that, and provide a little template for drilling the required mounting holes in the chassis....
I also had to open up the brake area a bit to fit the spur gear, but it is a pretty easy conversion. Mike is more than welcome to make a conversion based on my design, I would buy one just to get his awesome machining.
I also blew up one of the rear pinion bearings today. The small 8x12 bearings just can't take the load of the spiral cut gears.
I took an old Kyosho 8x16 metal bushing and machined it down to fit. It won't break, but now the rear diff is temping at 90-95 degrees I guess there is a little bit of friction. I guess I will have to get a bunch of the 8x12 bearings and just change them every dozen runs or so.
04.16.2008, 11:37 PM
Sike had the same issue with his inner bearing on the rear diff of his revo when using the spiral cut gears. I suggested making a spacer that would fit between the 2 bearings, and distibute the load onto both bearings. Basically it would allow you to clamp the bearings between the pinion and the drive cup, and it would be impossible to push the center out of the bearing. Just a thought...
Lonewolf039
04.16.2008, 11:48 PM
Good idea. I will do that as soon I can get some more bearings.
Lonewolf039
04.18.2008, 12:40 AM
I picked up a FlyCamOne the other day and tried it out. I mounted it in my E-revo and ripped around my yard. The camera slipped a little half way through and you can see the rockers doing their thing, looks pretty neat. The donuts can make a person sick though.
jhautz
jhautz's Avatar
04.18.2008, 12:51 AM
Cool vid. I like d seeing the rockers. Gives you a littel more apreciation for all the engineering involved in that suspension.
to make it...
or break it...
Silent...But Deadly
04.18.2008, 08:11 AM
That is cool indeed- its hard to visualize the rockers and how they work when just looking at a picture, but that vid gives you a really good view.
Fkyx
04.18.2008, 10:01 AM
Take the body off and do it again! lol
Cool video. :)
UH60sSuck
UH60sSuck's Avatar
04.18.2008, 11:30 AM
Where did you get that cam and how much did it run?
Lonewolf039
04.19.2008, 01:50 AM
I got mine from Great Hobbies in Edmonton, but it is distributed by Hobby Lobby. $99.99
Is is pretty cheap, but it seems to work OK. You will also have to buy an SD memory card, unless you have one from a digital camera. It is also firmware upgradable, which is a nice feature.
SpeedAssault
SpeedAssault's Avatar
04.27.2009, 10:18 PM
Very cool
whats the speeds and gearing ?
thanks for the cam info
Lonewolf039
04.28.2009, 01:24 AM
Very cool
14/46 pinion spur with the 4.3:1 truggy diffs. Geared for around 36-38 mph on 4s. I need thicker center diff fluid as it still diffs out quite a bit even with 120k.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 5.84
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3.29 : 1
Total Ratio: 14.12857 : 1
Tire Circumference (inches): 18.35 inches (466.01 mm)
Total Motor Speed: 30843.2 RPM
Vehicle Speed: 37.93 mph (60.93 km/h)
Effective KV Value: 2084
KT constant: 0.65 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Urgeoner
Urgeoner's Avatar
04.28.2009, 02:11 AM
Lonewolf that is a cool as truggy!! you oughtta market that center mount because I'd buy it!
SpeedAssault
05.08.2009, 04:11 PM
Wow I cant believe you where able to fit a motor with 14 and 46 spur and not hit stock drive shaft
howd you do that
small size of motor ?
how you like the gearing/speed ?
Lonewolf039
05.09.2009, 09:28 PM
howd you do that
I am using a regular 36mm motor with no finns, just the RCM heatsink. It is tight, but fits. If you are going to use a finned motor, you will have to grind the fins a bit to get it to fit. I like this gearing as it is easy on the esc and battery. It's also the perfect speed for my sandpit. If I was doing more open running, I would probably run higher gearing for more speed. It is quick, but not real fast as is.
