jhautz
jhautz's Avatar
04.18.2008, 09:39 AM
If you are looking for it to do TP or PW style packs they make a 1-5s adapter. that lets you plug any 1-5s PQ or TP pack with no hassle.
Here
I have this same charger and love it also. The software is awesome. I love the graphing capabilities and the internal resistance measuring thing is great for being able to see how strong your cells are and comare pack to pack. I use 2 of the adapters above to charge 2 5s 5000 packs at the same time. Works perfect except my PS cant handle the load. It starts to dip output volts and it causes an error on the charger so when doing 2 packs at the same time I just charge at 4.5A each. Not the chargers fault, my Power supply is not up to the task. I'm using a 30amp compuuter power supply according to the lable on it, but its really only good for 20A reliably IMO. I havent tried it yet, but its suopposed to be able to charge 2 different cell count and capacity packs at the same time too.
2 thumbs up for the CellPro 10s so far. Ive only had it foar a couple weeks, but I havent used another lipo charger since I got it and I havent run into the ceiling on the current that someone mentioned earlier either. I will probably be selling a couple other chargers soon. Anyone interested in a FMA BalanceProHD 6s with a123 capability? Perfect shape.
BTW: MacII. Plug it in to the USB cable and download the latest firmware for the charger. It fixes the low amp thing on the 1C automatic setting. I still prefer setting the output amps myself thouhg. The software also allows you to save 6 charging profiles in the charger so you just have to select the one that preset for the pack you want to charge. The software is very cool.
to make it...
or break it...
Silent...But Deadly
