bustitup
04.22.2008, 04:26 PM
Sorry first I've seen this but drive shafts you just use 2 rear normal 3.3 driveshafts if IIRC.
What do each of the batteries power? If one esc is on lipo and the other NIMH I think you will get a bit of a mess...
ok so your saying I should be able to use the standard split center shafts from a 3.3 revo?
yes batts will be the same type I was just checking the fit of 8 cell and a 8000 lipo
bustitup
04.22.2008, 04:27 PM
Originally Posted by neweuser View Post
I like it, good job. I would find a way to make sure the front esc wires do not get entangled in the spur.... :)
lol..yes I agree ..I have the gear cover for it
04.22.2008, 04:28 PM
Yes but I think you need two of the longer ones...rears
bustitup
04.22.2008, 04:51 PM
see heres what got me confused...look at these on ebay then go to #2 post in this thread and the ones on ebay dont look near long enough and there supposed to be front and rear and look to be the same lenght
http://cgi.ebay.com/NEW-TRAXXAS-REVO...ayphotohosting
TDC57
TDC57's Avatar
04.23.2008, 12:27 AM
Nice progress bustitup!.. cant wait to see it on the Road.. I bet you'll have yours done before I have GEVO completed!..
Please keep the updates coming..
Have a great one..
Shaun.
Nothing!.. Hahahahaaa..
bustitup
04.26.2008, 11:05 AM
very close to blast off
bustitup
04.26.2008, 11:07 AM
big greg
04.27.2008, 03:29 AM
things lookin real good, cant wait to see some vids...
Sammus
Sammus's Avatar
04.27.2008, 03:38 AM
Shall I be the first to say you shoulda spent you money on a MM and a Neu instead Haha just winding u up, should be fun to drive :P
bustitup
04.27.2008, 05:39 AM
lol...thanks guys...its ok.... i'm sure the future for this ride will be a MMM set up
Sammus
Sammus's Avatar
04.27.2008, 07:50 AM
Don't know if you figured out the driveshaft problem, but the 3.3 has the same length shafts front and rear (about 48mm) and the 2.5 had different front and rear (41mm front and 61mm rear). So maybe that explains why some people say run two rears.
IS there any difference in diameter though? (ie strength)
Sammus
Sammus's Avatar
04.27.2008, 07:53 AM
Is that the 3905 tranny and the 3.3 (extended) chassis? Is there any trick to get it to fit the chassis? I want to do the same to mine so I can run batts either side.
Or to make sure you could use 2 rears from the 3905 max (about 100mm long)
Fkyx
04.27.2008, 02:33 PM
Sick looking Revo!
Sammus: The 3905 centers are smaller in diameter than the Revo centers. I was able to run the longer Revo center and one of the 3905 centers with my 3905 tranny setup on the 3.3 chassis.
bustitup
04.27.2008, 03:00 PM
Sammus
its a 3906 tranny...I personal like it better because if your going to run two batteries the 3906 motor mount keeps the motors pretty much centered where the 3905 is lopsided and one of the motors will stop you from mounting a battery on that side
as far as it fitting ...look at post #2 in this thread and look at my under carriage you can see the trany placement ...just hold a emaxx tranny in the hole and you can see where it needs to be dremeled
yes I ordered a set of 3.3 revi drive drive shafts and if they wont fit i will order the two rear's off of a 3905 emaxx and trim them to fit
Thanks for the compliments guys....i'm real proud of this build from scratch...its very rewarding
Sammus
Sammus's Avatar
04.27.2008, 06:27 PM
I read a build the other day that says you can use a standard revo shaft for the rear and a 3905 rear for the front.
I've got my gear on its way :) I'll be running a single motor, so I got the single motor plate mount for the 3905 tranny - looks like itll stick the motor in the middle. 6s2p A123 here we come :)
