83gt
05.02.2008, 10:47 PM
The tekno mount sits far back from the transmission, so you must use the clutch adapter to reach far enough to mesh with the spur. A standard pinion will not be long enough to engage. The RC Monster mount is designed to be used with a spur, and sits closer to the transmission. It would not be possible, at least not easily, to use the clutch with the RCM mount, nor a standard mod 1 pinion with the tekno kit.
I've not used a clutch on electric before, but I'm plenty happy with the performance using the RCM mount and a standard mod 1 pinion on my revo.
Not sure what you mean by "how much power in the batteries ?".
J.
