MetalMan
MetalMan's Avatar
09.17.2005, 02:58 PM
The motor's rating means nothing when it comes to how many amps it will actually pull. On average, the motor will only pull 15-20amps. On bursts, though, the motor can easily exceed its rating. The Warrior 9918 is a controller that is made for car use, and the Baracuda is for boat use (although someone somewhere said that they had excellent results with a Barracuda in a car). If the 9918 gets hot, then a fan can be put over its heatsink.
