Need help making sense of Neu Dyno Charts
VintageMA
Need help making sense of Neu Dyno Charts -
05.06.2008, 02:57 PM
Can anyone help make sense of reading the Dyno charts on the Neu 15xx motors?
http://www.neumotors.com/20061222/Dyno_data.html
I understand what information the chart is trying to display, but I can't figure out how to read the data on the 3 axis compared to the graphs and the labels.
“Everyone has a right to be stupid; some people just
abuse
the privilege.”
VintageMA
Find all posts by VintageMA
2
mwry13
05.07.2008, 09:57 PM
To put it simply
on the bottom you have a Torque scale and to the left you have a amps scale
At 15 volts, the test data is as follows
as more power is applied, more amps are being pulled (hence the possitive slope for the amps line)
same goes with efficiency... for a 1515 at 15 volts... peak efficiency is at max amps pulled... (really good for speed runs / high speed tracks)
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
mwry13
Find all posts by mwry13
Linear Mode
Switch to Threaded Mode
