Just go Play
Just go Play's Avatar
05.06.2008, 07:24 PM
My batteries do not hold voltage as well as they should but still manage about 3.3vps @ 170A with normal temps... even so would that effect the current the motor required?
As for the 8xl it is the correct kv and has what I consider to be normal temps of 150f but it will pull 170A peaks which is more then my 1Y pulls.
I guess I'll have to borrow an amp meter so I can try to verify if I'm getting accurate readings from the eagletree and the MGM.
