MM Hacking "OverVoltage Issues"
Takedown
WARNING: May become violent.
Takedown's Avatar
MM Hacking "OverVoltage Issues" - 05.06.2008, 08:36 PM
Having an issue with my MM going into overvoltage when running 5s on my matrix tr truggy. Is their any way I can get past this limiter w/o modifying the board of the esc? I despirately need to run my 5s setup to see how well it works.
RIP- Tammy (9/14/08)
ICUBoy
05.06.2008, 09:04 PM
Sorry I have no direct data for you, but when I run 5S2P A123s into my MM in will overvoltage. However if I plug in the UBEC first, and power it up and then power up the transmitter, then the MM will arm with no issues. Works every time for me, but 5S LiPo (if that's what you are using) is a little different...
brushlessboy16
brushlessboy16's Avatar
05.06.2008, 09:11 PM
His esc arms and reconizes throttle input but wont spin the motor, mine is the same way, but i just flick it on and off a few times and it takes the pack below the overvoltage cutoff...
azjc
05.06.2008, 09:44 PM
I have not done this myself but from what what I have heard you can disable the LVC and use an external one or dont run with one and be careful not to run too long
brushlessboy16
05.06.2008, 10:34 PM
Were talking about the voltage being too high for the esc just for the record
05.06.2008, 10:43 PM
If just turning it off/on a few times brings the voltage down enough, maybe try setting the CC/CV threshold on your charger to something like 4.0v/cell instead of 4.2v/cell (if possible).
brushlessboy16
05.06.2008, 11:08 PM
Thats exactly what i told him, he said flicking it on and off dont work...
skellyo
skellyo's Avatar
05.06.2008, 11:15 PM
There is an easy solution to your problem. Click Here.
brushlessboy16
05.07.2008, 06:20 AM
yah ill just pulll 170 bux outta my butt... lol
Takedown
Takedown's Avatar
05.07.2008, 08:38 AM
Ok redownloaded the CC software and reuploaded the latest firmeware onto my MM and it works flawless.
brushlessboy16
05.07.2008, 08:40 AM
yay!i told yah TD
Takedown
Takedown's Avatar
05.07.2008, 01:24 PM
What did you tell me? I just redownloaded it.
jhautz
jhautz's Avatar
05.07.2008, 03:27 PM
This is what I do on the one MM I have that is a little finiky on 5s. It actually only takes setting it to 4.15v/cell instead of the standard 4.2
to make it...
or break it...
Silent...But Deadly
