DickyT
05.08.2008, 07:53 PM
throttle and brake end points both set to 100% (default) same as in the tc4, I set the steering trims the same at 121/98.
I have tried using the tc4 model on the tx as well as it bound to the same rx.
It will not take neutral setting.
I reprogrammed the mm as well to verify the radio is capable of programming an esc.
