TDC57
TDC57's Avatar
05.10.2008, 02:12 AM
Originally Posted by Fast5sRevo88 View Post
TDC; what drillin' mod do u have to do in order to make the brackets work on a G3?
Hay Fast5sRevo88..
Absolutely no drilling was required for me, but then again I was centered, where you will not be, the stock 3905 RX box lined up perfectly with the existing holes on the FLM chassis. Looking at my rig and knowing what you about to do you will have to drill one hole or you can simple use a thin piece of Plexiglas to cover the servo hole on the right side and then drill two holes (the same as the existing RX box) through the Plexiglas! The entire process should take you all of 20 minutes (piece of cake).. No worries..
Hope that helps?
Have a great one..
Shaun.
Nothing!.. Hahahahaaa..
