brushlessboy16
brushlessboy16's Avatar
05.11.2008, 03:24 PM
Well Adding onto the previous post, i found out i did not lose the front diff, the setscrew on the front center dogbone came loose. As for the rear diff..... its not so good, it got grenadedm both the ring and pinion are toast, 6 out of 13 teeth are broken off the pinion aand 4 teeth are off the ring..
definately getting steel gears this time...
