entjoles
05.13.2008, 08:01 PM
I'll be checking soon .
it will fit in mine
lutach
lutach's Avatar
05.13.2008, 08:23 PM
Originally Posted by entjoles View Post
it will fit in mine
You are lucky. Too bad you don't have a Mr. C kit . I can wait a few months.
entjoles
05.13.2008, 08:47 PM
im just glad to get one finally, i have waited long enough
lutach
lutach's Avatar
05.13.2008, 09:20 PM
Post some pics when you get it installed. It should look awesome.
entjoles
05.15.2008, 06:42 PM
its here
the only thing i didnt think of is that the can is bigger then my old motor so for now i can only go down to a 15 tooth pinion with my mech. brakes
ill try to run it tonight
***also i just updated to castlelink v 3.051 so i hope there is no cogging
Electric Dave
05.15.2008, 07:31 PM
Please report back...
First Test
entjoles
First Test - 05.15.2008, 08:33 PM
ok i got it in and it was geared 15/46
lipo lvc set at 12.8v, punch @ 60% and all settings were on low/lowest
almost zero cogging
After 15 min of hard speed runs(5 min) and bashing(10 min) temps were as follows...........
Mamba Max with holes in case,fan,novak cap = 110*f
Max Amps 4s 5k lipos = 115*f
Center Diff 30k = 145*f
Tekno Neu 1515 1y/f = 145*f
i feel that the gearing would be about right if i had a higher "C" battery, maybe a 16t for tracks with longer straights
i am very`happy with the results and cant wait till i get a better battery for this
Electric Dave
05.15.2008, 08:37 PM
Thanks for the post...
Did you hit the LVC?
I don't recall what motor you had in the XT8 before but I wonder how this one compares to whatever you had before?
Thanks man, I'm living vicariously through you for a little while here...I did order one (thanks Daniel) but as you said, you got the last 1y...
entjoles
05.15.2008, 08:47 PM
i did hit the lvc, and i had a 9xl before, the run times are about the same but the motor runs much cooler
also the thing i find funny is the motor and box had a manf. date of 5/9/08 so its only a few days old
entjoles
05.15.2008, 09:01 PM
now i have a ????????????????
do i need to gear up to reduce motor temp????????
thanks
Electric Dave
05.15.2008, 09:13 PM
See this (excellent) post:
http://www.rc-monster.com/forum/showthread.php?t=2200
It sounds however like everything is running in the warm or normal range. Maybe batteries are a tad too warm.
lutach
lutach's Avatar
05.15.2008, 09:25 PM
I think 115F for the battery seems ok. If they get up to the 130-140 region, then I would be concerned.
entjoles
05.17.2008, 09:32 PM
i just ran today on 5s , same set-up as above but i switched to 50% punch control and a lvc of 16.5v
15 min of good bashing and speed runs and i didnt hit the lvc yet
temps where..
mamba max..115*
motor..155*
center diff..165*
batterys..120*
i like this much better on 5s , so i will be getting a neu or a elite 25/30c battery soon and continue running the Mamba Max with fan till it fails or i can get a Monster Max
has anyone run these batterys yet? opinions....either the 25c 4800mah or the 30c 5300mah???
http://www.cheapbatterypacks.com/main.asp
Serum
Serum's Avatar
05.18.2008, 04:45 AM
For that price, i would consider buying Neu energy packs. the size of the 5300; 188mm long! don't know if you've seen that?
entjoles
05.18.2008, 08:21 AM
ill stick with the neu packs, i want to get the best pack for my $ , and i didnt notice the length
thanks
