pb4ugo
05.17.2008, 12:31 AM
Kyosho spur fits fine. Also, the pinion size will be depending on your setup. I run a 2000kv 1512 2.5d in my CRT and find my pinion choice to be around 15t. I'm only running 4s though. If worst comes to worst, you can run the LSP ring and pinions to give you more gear.
Also, if you haven't ordered your motor mount yet, I suggest ordering the car mount. Combine it with the diff posts from the car. You will have a much lower center of gravity this way. The motor slots will also be in a better location allowing you to use a fuller range of gears. I've never tried it, but I don't think the smaller pinions will fit on my setup (I accidently got the truck mount).
