Maybe for a little while before it conks out, but that's definitely over its rated limit (if it's rated at the same RPM limit as most feigaos). It's got a larger diameter rotor than a CMS motor, so you'd definitely be pushing the envelope running that motor that fast. Current draw would be hell too at the voltage required to get the motor up to around 65k RPM.
