05.20.2008, 05:01 PM
BG is the Novak 25v 2700uf cap going to work on 6s or should do you have a link to a 35v cap... Anyone know which caps the MMM uses? I thank you
05.20.2008, 05:19 PM
6s right off the charger is 25.2v, so no. It'll work, but I don't think for long. Not to mention the EMF spikes when braking will exceed this by quite a bit. I believe the MMM uses 35v caps, which gives a little leeway, plus you never want to run a cap right at its working voltage. Also, that Novak cap has a pretty high rating for its size and I think would heat up quite a bit.
I would use several smaller 35v or 50v caps in parallel - something around 330uF-470uF each. Obviously, you'd need low-ESR caps, so look for the 105*C rating. eBay has them sometimes pretty cheap (don't know about the quality), or electronic supply places have them too, but they usually require a large order.
05.20.2008, 05:42 PM
What length of warranty do the MMM's come with? I won't be able to get mine up and going for probably another month as still require parts to get my buggy going
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Something, anything, nothing
05.20.2008, 09:55 PM
One whole year, can beat that with a stick!  (or a whip)
05.21.2008, 12:18 AM
Originally Posted by Joe Ford
Anyone who has issues with a MMM...send it in with a copy of the service request form. We are making these top priority right now. We'll give you the fastest service possible as this is a new product, and you've all waited long enough to have fun.
http://www.castlecreations.com/suppo...quest_Form.pdf
hi joe
in my country, thailand, there are 3 MMMs. All 3 owners are my friends. I would like to know,.can we send all 3 failure MMMs in one mail box to CC if all 3 are fail?
5th Scale Guy
05.21.2008, 07:06 AM
I think the failure rate is much higher. Eric locally. Killed one, and was testing his second Sunday at the track. He had to work and arrived late to race so wanted to test a few laps with his new monster after racing. I had to work that night and packed up after racing. As I was driving out I see Eric carrying his buggy to his car and he said he was allready showing signs of intermittant problems after a few minutes of running. Last I heard, he'd killed MMM #2 that day and waslooking for another MM to put in.
05.21.2008, 07:40 AM
finfin - I'm sure it will be fine - They wouldn't know they weren't all yours!
Castle's Chaos Corner
05.21.2008, 05:02 PM
Originally Posted by finfin
hi joe
You can send them all in one package. We will ship back to whoever sends the package in.
Joe Ford
Product Specialist
RC carbon junkie
05.21.2008, 06:19 PM
Darn my second MMM died.I switched my 1515/1.5 4s for my 1515/1d on 3s 6000.It just stopped like the first one.The 1515/1D max amps is 200A.The system wasnt even warm.It ran flawless yesterday with the Tekno Neu 1515/1.5d.I should not have swapped the motors
Losi 8T MMM? Tekno Neu 1515/1.5/f 4s 6000/Neu 1515/1d/s 3s 6000
Crt.5 Quark 80B Neu 1512/1d/s 3S 6000
E8ight T
05.21.2008, 06:29 PM
Probley was going to die soon anyway, by swaping motor/batteries, just showed the esc was a bad one..
that does suck though
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
05.21.2008, 06:51 PM
So, if i get a Monster, is it guarenteed to fail  ? Or should i be ok, i guess if it does fail Castle will be glad to fix it right?  Do they know what causes the problems yet?
05.21.2008, 06:54 PM
BrianG and myself are waiting for everything to nice and ready before we jump in. I've been around the electronics scene for a while and I learned never to jump in first. Keep in mind that Castle's failure rate is one of the best I've seen. Castle also has what might be the best service in this industry.
Yip Yip Yip...
05.21.2008, 07:51 PM
That's OK for you and brian who already have high power handling escs. People like me who have a quark 33a and some other tiny esc have nothing to loose.
05.21.2008, 07:54 PM
Hey, I want a MMM just as bad as anyone else. I also want a SMMM  .
05.21.2008, 08:25 PM
Yeah, I kinda figured there would be some minor issues to iron out. Everyone else can be testers.
