azjc
05.25.2008, 11:30 AM
the GT10 is a Lightning stadium 10 with max size wheels, 8 shocks and a bigger nitro motor, a 9l feagio on 3s is MORE than enough to keep you entertained and has to be tuned down for the track. i would say go with the 1509, your truck should weigh about 6 puonds rtr due to the larger tires and extra 4 shocks, while my ls10 barely touchs 5 pounds. the 1.5d is too high a kv motor, youll want a 2700 kv or so motor if you wana to beable to get to gearing to an acceptable range, im not sure which nue motor this is but hopefully someone else will chime in on that casue i dunno
do you plan on using mikes motor mount? youd want the one for the lightning stadium 10, its a direct fit.
you should really enjoy it, gear it for 40mph and you should have ATLEAST 45minutes of runtime, and please post some pics
1509/2.5d is 2700 kv which is the same kv as a Feigao 9L
