hoober
05.27.2008, 10:44 AM
In addition to above, it will depend on what voltage you can tolerate. If you need 1.2 volts the current isn't going to be very high unless you use best cells, if you can tolerate less than 1 volt/cell then the current can be far higher and you can get away with cheapo cells.
