drkros3
05.27.2008, 11:44 AM
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 2779
Tire Diameter (inches): 3.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0041
Spur/Pinion Ratio: 1.64 : 1
Total Ratio: 4.46281 : 1
Tire Circumference (inches): 11.78 inches (299.24 mm)
Total Motor Speed: 61693.8 RPM
Vehicle Speed: 154.22 mph (247.74 km/h)
Effective Speed Rate: 6.95 mph/V (11.16 kmh/V)
Estimated Adjusted Speed: 119 mph (191 km/h) - 23% loss
Effective KV Value: 2779
KT constant: 0.49 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified..
thats what i got when i put it in the speed calculator
