06.01.2008, 11:26 PM
Yeah, 60mm is okay, but 70mm will be best by far- being as they 4 pole motors then 60mm version is very similar to a neu 1512, so....
It all depends on gearing and weight. If you have a heavy truck and want it to go fast then you need a big motor, like a 1515 or larger (or possibly a low kv feigao xl and 8s lipo). If your mt is light, then the medusa 60, or a 1512 or a feigao xl will do. More info on the intended setup would be necessary.
