lipos and water
mkrusedc
NeuMaxx
mkrusedc's Avatar
lipos and water - 06.02.2008, 12:43 PM
Can I run lipos in a "water proof "truck like the new Traxxas E-Revo?
cmcclive
06.02.2008, 01:32 PM
I think that LiPos are not water proof and I have heard that if the LiPo itself (not the casing, but the polymer) gets wet bad things happen.
Perhaps coating the battery in plastidip and inspecting it before wet weather usage would be adequate?
Although, now that I think about it sense the E-Revo has enclosed batery trays you might just be able to seal them (silicone caulk/RTV along all seams, make sure there are no gaps)
06.02.2008, 01:53 PM
As long as you have good lipos that do not get hot during use, you can plastic-dip them and it will not matter if they get wet.
rcsammy
buggy beater
rcsammy's Avatar
06.02.2008, 01:56 PM
batterys can be sealed in a large balloon with grease and zip ties around the neck
but imo its not worth risking a lipo pack
  Send a message via MSN to rcsammy
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.02.2008, 02:47 PM
Thanks, I guess if i want to run my E-Revo "waterproof" NiMh is going to be necessary.
cmcclive
06.02.2008, 03:00 PM
what about A123? I am guessing that they are as water resistant as NiMH.
Honestly though, do you plan on only running it through wet areas? (you could get a set of lipos and NiMH and save the NiMH for wet days)
bruce750i
bruce750i's Avatar
06.02.2008, 06:08 PM
I've submerged my 3905 emaxx on teen titans and NimH 62p. Water filled tires get heavy and suck to dry out. Everything else was fine after a proper lube job. Lipos only if you have to I'm sure the boat guys have their ways on waterproofing. http://s300.photobucket.com/albums/n...t=MOV02658.flv
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.02.2008, 06:31 PM
They won't fit in the new sealed battery trays, which are 165X51X30
jnev
jnev's Avatar
06.02.2008, 08:51 PM
With my Revo, even though all the electronics I have are waterproof/waterproofed except for the lipo battery, I just wrap the whole chassis with saran wrap a couple times. Works great!
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.02.2008, 10:31 PM
No heat issues?
