jhautz
jhautz's Avatar
06.04.2008, 01:47 AM
Originally Posted by Joe Ford View Post
When extending leads past recommended length (12" from where the Batt wires solder to t he ESC and where the wires solder to the pads on the lipo cells) you must add an extra cap of equal uF rating and voltage. Every 4" of added length, add a cap.I use a pin soldering ti to poke holes in the wires right off the PCB, insert the solder "legs", and fill with solder.
Great tip Joe. Thanks.
Is there any detrimental effect to adding extra caps even if you dont add wire length?
to make it...
or break it...
Silent...But Deadly
