If you push on the tabs only as much as you need, you shouldn't break them. Just loosen one, and gently apply a little opening pressure on the case to keep that tab from relocking while you work on the other ones.
If you get a fan with different connector than the one on the MMM, then yes, you'll need some soldering.
