Desmo
06.10.2008, 12:39 PM
My 16018 make a bizzare thing last night. I put the switch to ON and when i pull the trigger, the controller don,t want to do anything. The steering servo operate, but not the controler.
I have put the switch back to OFF and put it back to ON again, and all was OK for the hole pack.
And another thing, i can,t pull more than 3500mAh of my pack before the LVC kick. My pack is a Flightpower 5000mAh, 4s, 25C, and my controler is on Reduce RPM mode.
I believe it needs to see netural when switched on or it won't work. Its a saftey feature. My Heli esc's all work like that. As with all electroincs I always power down and back up when something strange happens.
Sounds like you pack can't handle the load at that point and the draw drops it below the LVC. Search the forums here there are others with mgm lvc issues.
