MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.11.2008, 02:34 AM
Originally Posted by DRIFT_BUGGY View Post
Oh, so everytime you want to program the BEC you have to un-solder the battery wires? Does this also work with the ESC then?
If you want to program the bec unplug the bec from the receiver and plug it into the castle link. If you want to program the MMM, unplug the MMM from the receiver and plug it into the castle link. There won't be any confusion that way. Nothing will need to be de-soldered either. The receiver wire on the bec or MMM should not be connected to the receiver in any way when programming via castle link.
Have I missed something?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.11.2008, 02:38 AM
Originally Posted by tc3_racer_001 View Post
id imagine you would only have to unsolder one? glad to know (i just assumed that this was the case)
Unsolder what? I don't see a reason to unsolder anything.
azjc
06.11.2008, 07:39 AM
you should only have to program your BEC once, the fist time I programmed a CC BEC I installed before and had issues and I called Castle and I was told to program first but I wonder why when you try to tweak the ESC the confusion doesnt work the other way
