Ammo motors for dual brushless set up?
Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
Ammo motors for dual brushless set up? - 06.13.2008, 08:58 PM
I've decided I want to utilize my dual motor mount E-maxx transmission in my Revo while still use my VXL controller.
So the plan is to get another VXL and then get two motors to go along.
I want to get two motors for under $140. I have it pretty much narrowed down to:
2 Velineons
2 Ammo 36-56-2600
Feiago L motors might be a little to costy with the heatsink clamps added into the price. These are going to run on 3s. The Ammo motors would be cheaper, as they are $35 a pop at Tower. Seems too cheap. Would they hold together? It looks as though they don't have any screws holding them together.
Dual Velineons would be fast geared 19/62. Wanted to know if I would be able to get comparable speeds if I geared up the larger ammo motors.
bdebde
That's All Folks!
bdebde's Avatar
06.13.2008, 10:53 PM
I believe the Ammos do have screws in the endbells. But they also have holes in them like Neus.
06.13.2008, 11:09 PM
Go with the ammo motors, although at 2600 kv, motor speed may be a bit low. Temps will most likely be good with the slower spinning motors, and using 2 should be ok with higher gearing.
tc3_racer_001
tc3_racer_001's Avatar
06.14.2008, 06:23 AM
had a single ammo in my e savage. in warm/hot temps, the motor got pretty hot (too hot imo) but never thermalled or showed any signs of giving up... the 2 year warrenty is always good, and they dont have screws, just pop off/on, a bit of glue or 2x clamping heatsinks work perfectly, but i didnt bother, was very tight!
same or better than the feigaos aparently.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
06.14.2008, 12:13 PM
Hey guys, I just fried my mamba 5700 motor in my stampede, and thought I'd look at the ammo motors because of the price. Do you think the 36-50-3300 is enough motor for the stampede on 3s?
06.14.2008, 12:17 PM
2 Velineons
2 Ammo 36-56-2600
Because of the amp capability with the velineon ESCs, why not just run the motors in parallel (I guess) and just run them off of 1 ESC because the total anp draw of both the motors in parallel is only 110a continuous and 180a burst-- still under the 200a capability of the velineon. Just a thought...
06.14.2008, 06:39 PM
Thats assuming the 200amp sepc of the VXL is true or accurate, wouldnt like to test it myself really.
For your pede, I reckon the 36-50-3300 would be fine on 3s, slower than your 5700 mamba but then again you should be able to gear up more with the ammo.
06.14.2008, 06:43 PM
I'd probably gear it a bit lower actually. It's just uncontrollably fast, and I just picked up a wheelie bar. That's a lifesaver. if you've ever heard the back edge of a body scraping on asphalt, a wheelie bar is a must for all brushless trucks.
Topspeedtimmy
06.14.2008, 07:18 PM
Which ammo motor and was it a nitro conversion or the light electric one? Was it a viable power plant with a good top speed?
tc3_racer_001
06.14.2008, 07:25 PM
hi there. it was the electric one with a few upgrades... it ran hot on stock gearing, but was pretty darn quick. (didnt help that i had the pinoi drilled myself, and wasnt completely square, and the batteries i was using were useless (cheap 12nimh). on good lipo and mamba max, this thing would have run a whole lot cooler, but i cant really say wether its a viable single option. its the same as a feigao 9L performance wise for 1/2 the price and 2 year warrenty. hope this helps.
ryan :)
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
stum
06.14.2008, 09:57 PM
First off brushless motors cannot be run in parallel off one esc, only BRUSHED can be used this way.
Go w/ another velineon, it is a proven setup that will net you about 50mph with a sick amount of torque on a pair of 3s lipo's. You will need a revo Y-harness for the radio and you will need to make a parallel connection to the pair of esc's and batteries so both esc's LVC kicks at the same time.
06.14.2008, 10:41 PM
Yes they can - You can sync the motors up so they can run of same esc - Do some searches on rcm it has been done before Artur i think posted the instructions.
The ESC needs to be capable of supporting all of the amp draw.
06.14.2008, 11:11 PM
Has anyone drawn a diagram of the wiring needed?
Five-oh-joe
06.14.2008, 11:59 PM
While it's possible, it's definitely not the best option for a reliable setup at all. Not worth it IMO.
06.15.2008, 12:44 AM
Single motor/single esc is the best bet. Sell the vxl, buy a MM, and a ccbec. The get an 8xl and run it off 4s. It will be a lighter setup ,and have plenty of power. I have a pair of axeo motors that I plan on running on a quark 125b on 5s. Just have not got around to doing it yet...
