outrunner in a revo.
traxxasrevony
outrunner in a revo. - 06.15.2008, 06:18 PM
i was thinking about using a outrunner in my revo once i got my mmm back but i would have no clue as to what motor to use. would i be able to get a outrunner that would bolt right up to the rcm mount?
any links would be very great
thanks
06.15.2008, 06:52 PM
If you're talking about a nitro conversion, then there are a couple good options. The AXi 2826-8 or 10 models are good, or the turnigy equivelants (diffeent shaft size though I think).
http://www.rc-monster.com/forum/showthread.php?t=9793 best place to look for tips, just bear in mind the different transmission ratios.
traxxasrevony
06.15.2008, 07:04 PM
so would this be a good setup the 2826/08 on 6s with the mmm on 25/36 gearing for 50mph?
and it would bolt right up to a 540 sized brushless mount
06.15.2008, 07:14 PM
Not really. 4s lipo is the most you can run practically, since these higher kv outrunner motors dont like to be spun that fast- you make the power and speed through gearing. 22/40 gearing gives about 40mph or so. I would suggest following that link I posted and carefully reading all the info presented. Sike knows his stuff when it comes to outrunners.
traxxasrevony
06.15.2008, 07:18 PM
how many amps should i enter on the speed estimator this is what i got with 70 amps on 22/40
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.5
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 22
Total Voltage: 14.8
Motor KV: 1130
Tire Diameter (inches): 5.9
Tire Ballooning (inches): .5
Motor Current Draw: 70
Motor coil Ω: 0
Spur/Pinion Ratio: 1.82 : 1
Total Ratio: 12.93706 : 1
Tire Circumference (inches): 21.68 inches (550.6 mm)
Total Motor Speed: 16724 RPM
Vehicle Speed: 26.54 mph (42.63 km/h)
Estimated Adjusted Speed: 26 mph (41 km/h) - 3% loss
Effective KV Value: 1130
KT constant: 1.2 oz-in/A
Motor Torque: 0.44 ft-lbs
Final Torque: 5.64 ft-lbs
Final Power: 1036 watts (1.4 HP)
06.15.2008, 07:30 PM
I tend not to worry about amp draw and that stuff, thats more to do with determining power output than speed. I didnt realize the revo tranny is geared so low- 2.5 vs 1.83 or 1.72 for the new and old emaxxes. Gonna have a hard time getting much more speed out of it unless you can up the tranny ratio. 2nd gear wide ratio is better, but still only about 30mph. The old emaxx tranny allows for 38mph, and the new tranny 36mph.
You could gear up a tooth on the pinion, or look into an equivalent outrunner with a slightly higher kv, but its all abit out of area of expertease... Sike be the man to talk to, thats your best bet.
traxxasrevony
06.15.2008, 07:40 PM
i had the wide ratio gear set but with my 8xl/mmm/4s and 20/40 gearing at 45 i punched it for a radar run and the front end came right up.i let off to bring it back down and grenaded the tranny that locked and i snapped my front center driveshaft. i wanted to get it running in a hurry and all the hobby shop had was the close. so thats what i got.
im completely happy with my setup now i just wanted to try somthing diffrent. i think im gonna study up more on outrunners then start the project
