3905 direction on 3906!!
e-mike
e-mike's Avatar
3905 direction on 3906!! - 06.17.2008, 11:51 PM
i do this little modiff on my maxx....more precision , better control!! and no more servo saver on the servo
rommel
3905 direction on 3906 - 06.19.2008, 10:55 AM
what do you mean by this bro? this regards to the servo linkage or what? by doing this mod will greatly help the steering?
06.20.2008, 05:48 PM
Use your eyes dude! He has installed the 3905 servo saver bellcrank assembly onto the old emaxx, thus meaning he doesnt have to use a normal servo saver on the actual servo(s). Its basically like installing a proline kit onto the old emaxx.
rommel
06.20.2008, 06:20 PM
yah i know but im about to do this mod...im going to use another servo saver to my E 3905... but recently i just replace the the plastic bushing to a tamiya ball bearing that measures 5X8X2.5mm i use two of them...my question is this is it necessary to use two servo saver if i had replace the plastic bushing to ball bearing or i should stick with it...by the way im using 2 tower pro mg995 servo on pcm mode in my 3pk super synthesized tx...any comments will greatly appreciated tnx
e-mike
e-mike's Avatar
06.20.2008, 06:24 PM
i think that one saver will be ok for the sterring
Duster_360
06.20.2008, 08:34 PM
There's a thread over on TRX about this and it is the mod they're doing on the 3905 - add another saver to eliminate strg slop, it is not used for more "saving" - thats disconnected. I looked at doing it on my old 3906 and at $35 BIN on ebay (all I could find) decided I'd pass and put the brgs in the stock strg. The older 3906 doesn't seem to have the strg slop that the 3905 seesm to come with.
http://monster.traxxas.com/showthread.php?t=403852
I have been using an alum version of the stock strg arms made by powerline in my Tmaxxes, but they've been discontinued.I wanted to do the same here.
Did I read somewhere that Proline has put an improved version of their saver back on the market or was that just a rumor??
06.21.2008, 04:47 PM
You are in luck- both Newera and GPM sell an alloy version of the steering bellcranks ( I have GPM version, very nice & came with bearings- ebay purchase).
Duster_360
06.21.2008, 09:49 PM
Thanks for the heads up Neil! I'll go looking for the gpm versions.
