MetalMan
MetalMan's Avatar
09.28.2005, 11:22 PM
Originally posted by squeeforever
whats the best CHEAP lipo set up i could run with my e-revo? i plan on running a 7xl and at least 5s lipo. maybe 6 if the 7xl and warrior can handle it. also, im looking for at LEAST 6000mah and would like to be able to balance them and somewhat of fast charge them. like an hour or hour and a half?
Go for the 5s Lipo. It won't disappoint you. With 5s 6000mah, you are going to spend quite a bit. Just to give you an idea, it will cost $300-350 depending on the brand and quality).
Modern Lipos can be charged at 1C, which means one hour to do about 90% of a charge, and then another 15-30mins to do a 100% charge. Some cells, like the Kokam 3200s can be charged at up to 3C, so that means 20mins for 90%, and maybe ~45mins for 100%.
To balance them, you could by the Thunder Power balancer, and just stick the proper plug(s) on depending upon the brand of the battery.
