Pdelcast
Pdelcast's Avatar
06.23.2008, 10:27 AM
Originally Posted by Django View Post
I'm not running any punch control, atm. The setting is 0. Are you saying I should add some to it?
My gearing is 25/58. I can go as far as 25/54 with what parts I have on hand. What would you suggest?
Adding some punch control will lower your peak currents -- so if you think you are bogging down your packs, it will help keep the voltage from the packs more steady.
Try going with the 25/54 gearing and see if it helps with the hesitations/bogging. Usually those issues are current related -- too much current and the batteries just sag badly. Both gearing and punch control can help lower the peak currents.
Patrick del Castillo
President, Principle Engineer
