06.23.2008, 05:38 PM
Makes sense. A signal is a signal, it's the user input method that changes.
Did you try to flip the throttle cable around on the receiver?
Jeremy1976
06.23.2008, 05:43 PM
Is it normal for the ESC to get warm from calibrating it? I temped it and it is 114.
Jeremy1976
06.23.2008, 05:44 PM
It is on right.
06.23.2008, 05:45 PM
You need this!
Aux: None
Thr: ESC plug in here.
Str: You need a Y adapter and both steering plug going in here
Bat/Tel: BEC plug in here
Did you disconnect the red lead on the ESC lead - If not stop and do so now... before smoke!
Jeremy1976
06.23.2008, 05:50 PM
You need this!
Aux: None
Yes orange red and brown. I disconnected the red which is the middle one.
Jeremy1976
06.23.2008, 05:53 PM
LMAO. Looks like I will have to wait another couple of days to get that y adapter for the steering........ Even then I will probably not be able to get it working..... Ready to throw it out the window.
06.23.2008, 06:00 PM
For now just use one of the steering leads... and follow above
Jeremy1976
06.23.2008, 06:05 PM
Is it normal for the ESC to get to 114 degrees when trying to calibrate it?
Jeremy1976
06.23.2008, 06:24 PM
Okay I got it. Now I just need to get that adapter.
06.23.2008, 07:21 PM
Not really - tad worried that you might be still using the interal bec - any chance of photos
Jeremy1976
06.23.2008, 07:41 PM
What do you want pics of? I can take them for you so let me know. Ran in the driveway for about 5 minutes and a couple high speed passes with wheelies and the ESC got to 186, motor 118, lipos in the 80's. Maybe I need a fan on the MM.
06.23.2008, 11:14 PM
Please post up details of your setup - Car, battery, motor, gearing etc.
If 4s then yes a ubec, fan and cap
