azjc
06.27.2008, 01:23 PM
Originally Posted by TruckBasher View Post
Ok just got my MM from the mailman today. Now I am a bit hesitant after reading a lot of MM setup..
Few of which:
- MM is a hit or miss on 5S
- MM not intended for Monster Truck
Need your consensus guys...Do you think MM can handle my 13lbs truck and 5S A123?
Also disabling BEC means just removing the red wire, right?
when we say 4s it refers to lipos which would be equal to 5s a123 and yes the red wire is the power wire so removing that disables the onboard BEC and the lighest color wire is the signal, and there is no reason a MM cant handle a MT it would be more the motor not having enough torque, before the MMM came out a popular setup was the MM 4s lipo with a 2200 kv motor
