Cartwheels
07.01.2008, 01:38 AM
I cut a piece of 1/8th inch aluminum with a hole saw that is the same diameter as the motor for the front. Drill a couple of holes in it for the mounting screws. Works well. Even allows some heat dissipation to the motor mount. I use the RCM cover on the back.
