david lamontagn
07.01.2008, 10:00 PM
I think that with my 1515 2.5d and 6s, i'll be not to bad with 22/68, but i've RRP MOD .8 pinion 20T and 21T on the way
VintageMA
VintageMA's Avatar
07.01.2008, 10:09 PM
David - you and I are running the exact same setup with the badlands - and running last weekend on 18/62 (equiv to 20/68) I can see 20/62 (24/68) being a good setup - but the badlands really don't balloon too bad.
You had recommended the badlands setup to me in a pm and I got the tires with the maximizer bead locks and they are a perfect bashing combo.
With the regular stock Talons you might as well take the diameter of 5.9" and add an additional 2" to the diameter if you gear for 35 or more.
SJCRSS - if you have the options of getting a few pinions I would go low and then work your way up, but either way you will love this truck - I've been having a blast with it so far.
“Everyone has a right to be stupid; some people just abuse the privilege.”
david lamontagn
07.01.2008, 11:02 PM
I'll try 20/62 at first, and if my component is to hot to my taste and runtime to short, i'll drop it to 20/68
VintageMA
VintageMA's Avatar
07.01.2008, 11:15 PM
Regardless of motor or battery - if your setup is going to be around 30,000rpm - do not run 24/68 with the stock tires - you'll overheat the motor when the wheels balloon because the motor will be way overgeared at speed.
azjc
07.02.2008, 03:15 AM
I have a set of Badlands and Maximizer beadlocks also , they are still in the package waiting to be assembled I am presently running a set of LPR Crimefighters on my BL Revo
