lipomax
02.27.2005, 02:19 AM
I did try the basic 2100 motor the other day on 11.1 volts geared 28/72 x 2.5. It was okay for speed and acceleration - but when a motor spins too slow, you don't have as much fine motor speed control as you would if the motor was spinning a little faster. It seems like when a motor spins around 40,000 rpm it's easier to drive than a 20,000 rpm motor.
I'll have the emaxx tested by the end of next week. I'll start with the Feigao 10L with 22.2 volts comparing polyquest 3100 vs. Kokam 3200 vs. Kokam 2000. I'll have it geared 18/66 and use only first gear. That should give me a result of about 30mph in first gear. RPM should be right about 50,000 rpm. I'm gonna guess about 65 amp draws during acceleration... We'll see.
