Batfish
Batfish's Avatar
10.03.2005, 09:46 PM
Originally posted by RC-Monster Mike
I believe it is a voltage cutout you are experiencing. As the batteries run down, there voltage runs down and a hard start(rapid acceleration) will drop the voltage low enough to trigger the controller to cut out. If you put the controller in "race mode" on the low voltage option, it should eliminate this, unless your total voltage drops below 5 volts.
Mike,
I'd agree, except that with the voltage cut-out on the MGM we still have servo control, whereas with this specific cut-out there is no servo control until the controller beeps and re-arms.
Joe
