Finnster
KillaHurtz
Finnster's Avatar
07.09.2008, 08:34 PM
I was going to say the hyper buggies share the same part. I have a set of gaskets like that and they don't quite match up. You may be able to poke holes, but only two screw holes line up on the spiders. I would try to get the orings either way to be safe.
FWIW tho, I've heard those gaskets are good on the other diffs to keep them from leaking as the orings are a bit lame.
