Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
brushlessboy16
brushlessboy16's Avatar
07.01.2008, 01:17 PM
yay
07.01.2008, 01:30 PM
Disagree with the math - On the range condition that A or B equals the target - this is fine it should just be 100% / 0% mix...
I had included >= in the forumla
07.02.2008, 02:42 PM
Oh all right, I made the formula inclusive instead of exclusive. It would be pretty dumb to mix anything with say 50w oil to get 50w oil, but I suppose...
Also reworked the two-speed calc page to make it a little easier to use. Also added a couple things to the gear diameter calc.
kopfpilot
07.10.2008, 06:46 PM
Is it possible to add the E-Savage to the presets?
07.10.2008, 06:54 PM
Sure, just give me the tooth counts of all the tranny gears and the diff...
kopfpilot
07.11.2008, 02:45 AM
Thanks =)
The specs for the E-Savage:
Front/Rear Differential Gear Ratio: 38/13
Transmission Gear Ratio: 33/19
Spur Gear: 66T 32P (Stock)
Could you add the Ammo 36-56-2600 brushless motor aswell?
It has 2600KV, 55Amps current draw and a ressitance of 0.0084Ohm.
07.11.2008, 10:04 AM
I'll add those ratios, but I try to stick to motors that Mike sells, will sell, or used to sell.
Any other changes people want before I upload the updates?
brushlessboy16
07.11.2008, 10:31 AM
umm isnt the rpm limit of L motors 50k?
skellyo
skellyo's Avatar
07.11.2008, 10:36 AM
Can you get it to make me a sandwich when I hit the calculate button? I'm kinda hungry.
07.11.2008, 10:47 AM
blboy: Yeah, maybe so, but people have found that the max "effective" rpm is 40k, so that's what I used.
skellyo: Will do...
EDIT: Actually, this will work for you. Why re-invent the wheel?
Virtual Sandwich
Sim Sandwich
skellyo
skellyo's Avatar
07.11.2008, 11:03 AM
skellyo: Will do...
Virtual Sandwich
Sim Sandwich
Close, but the Pepperidge Farm site didn't give a pic after I built it. I think I'm going to have to head to Firehouse and pick up a sub for lunch.
07.11.2008, 11:05 AM
Probably a good idea.
I'll be going to Subway for lunch for my usual roast beef on wheat with Chipotle sauce, lettuce, tomato, onion, pickles, black olives, and S&P.
07.11.2008, 03:33 PM
E-Savage ratios added. Sorry skellyo, no sandwich function...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.11.2008, 03:36 PM
Skellyo, as soon as I finish constructing my SUB-atomic matter compiler I'll have it "make" you a sandwich!
Do you want mustard?
skellyo
skellyo's Avatar
07.11.2008, 04:14 PM
Of course I want mustard....unless you can just put a little balsamic vinegar on it instead?
Currently Active Users Viewing This Thread: 17 (0 members and 17 guests)
