azjc
07.11.2008, 03:20 PM
Originally Posted by rcsammy View Post
what plugs will i need to order to get the feigao to connect to the mamba max? my MM is in for repairs and i dont know what size the bullet connectors are
the MMM comes with 6.5mm connectors but you will need to solder them on yourself, they do take a little more to solder them on than smaller connectors, I think you would be fine if you used 5.5mms especially if you run more than a 4s pack...when you solder them on just make sure you use at least a 75 watt iron otherwise you wont have enough heat the bigger connectors act as a heat sink
