sikeston34m
sikeston34m's Avatar
07.11.2008, 06:22 PM
I just did a test run in my E Revo with a 36-50-2600 Ammo motor.
Power is there! You can't hit wide open throttle without doing a standing backflip. Wheelies at speed, rooster tails of gravel, the whole nine yards.
The only thing is, on 4S 5000mah 20C Lipo and geared 20/68, it does tend to get hot after about 10 minutes.
I'm not running a heat sink yet, but will be running a heat sink and a motor fan to see if that helps. I may still be geared a little too high. Top Speed is up there.
I can tell it's pulling some amps since I'm detecting some heat from the 125 amp Quark Monster Pro.
Quite the Peppy Motor if you ask me. I just have to get the gearing right and the temps in check.
