07.17.2008, 09:17 PM
What is the bolt pattern? The nitro Revo (mod1) and Jato (32p) use the same bolt pattern (3 hole); I can't imagine Traxxas would change it for one vehicle, especially since most of the newer vehicles use the Revo-derived slipper setup. The only trouble you may have is finding a ratio that will work. AFAIK, the Revo spurs only go up to 40T, which limits the pinion selection. Just do the calculations to see how things work, and if the ratios work, you have nothing to lose by trying one out.
