Pdelcast
Pdelcast's Avatar
07.18.2008, 12:07 PM
The new stencil will be in on Monday, and production will resume then.
Patrick
People -- don't complain that I don't give straight answers... How do you get more straight than this?
The new stencils will be in on Monday, and production will resume then. THAT MEANS PRODUCTION WILL RESUME ON MONDAY.
For those of you who need further clarification... That means that we will start building Monster Max controllers again on Monday.
If that isn't clear enough for you -- here's some more details.
On Monday, about 9:00am, UPS will deliver a pair of MMM stencils. A stencil (in the electronics world) is a large piece of nickel plated stainless steel, about .006" thick, stretched tight into a 29" x 29" tubular aluminum frame. The thin sheet of stainless has apertures cut out of it with a laser, and is used for putting solder onto a circuit board. The solder is printed onto the circuit board using a machine called a "stencil printer." Our stencil printer is a Dek Horizon printer. You can click on the link below to get more information about the Dek Horizon stencil printer:
http://www.dek.com/web.nsf/us/product_horizon
Our machine operator, Shawn Messmer, will load the Horizon printer with the solder stencil for the top side of the Monster Max first. He will then load solder paste (which is a paste made of microscopic solder balls suspended in flux), and start production.
After the solder is printed on the circuit boards, they then move out of the Dek Horizon (by conveyor), and into our Universal Instruments Advantis Lightning (AC-30L). Our Advantis AC-30L is our chip shooter, and will place about 32,000 parts per hour onto the MMM circuit boards.
After leaving the Advantis Lightning AC-30L, the board will move by conveyor to our Advantis FlexJET AX-72. The Advantis FlexJET is a little slower than the Advantis Lightning, but can place larger, more difficult parts. This type of machine is usually called a "flexible placer", where the AC-30L is called a "chip shooter."
To see more information about the Universal Instruments Advantis, visit this link below:
http://www4.uic.com/wcms/WCMS2.nsf/i...oducts_18.html
After leaving the Universal Instruments Advantis AX-72, the MMM boards will move through the reflow oven, a Heller 1707EXL. The reflow oven solders the board (all at one time!) by raising the temperature of the board slowly until all of the solder paste (stenciled on by the DEK printer!) melts, or reflows. To see more information about the Heller 1707EXL reflow oven, visit the link below:
http://www.hellerindustries.com/h1700EXL.htm
After reflow, the boards cool for about an hour. Then it is off to the inspection station, where we employ a MIRTEC 5 camera automatic optical inspection machine, which checks all the parts and solder joints to be sure everything is perfect after assembly.
To see more about our Mirtec 5 camera AOI, please see below:
http://www.mirtecusa.com/desktop3.html
Once all is checked and found to be OK, the MMM will then move into soldering, where our soldering technicials will add the switches and receiver connector (with love, of course!)
Then the boards move on to final assembly, where they are placed in cases and stickers are added to the case.
Next, the nearly complete MMM move into functional testing -- where each and every MMM is calibrated, and tested with loads of up to 100A. During functional testing, the output waveforms, throttle response, and cutoff voltage settings are all throughly tested.
After passing functional testing, the MMM move to finishing and packaging, where they are carefully placed into a box along with a CD, cable and Castle Link.
Then the MMM are moved into stock, where they will await final packing and shipping.
Hope you found that interesting!
Patrick
Patrick del Castillo
President, Principle Engineer
Mad Max
07.19.2008, 06:02 AM
Wow - thanks for the detailed information.
So Castle Bullets are no longer included in V2?
Cheers,
Wolfgang
XT8 - Neu-Castle 2200 KV - MMM V1 - 5S
eRevo 5605 - 11XL - MMM V2 lite - 6s
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.19.2008, 06:14 AM
Patrick
lol, that is pretty straight
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
phatmonk
RC carbon junkie
phatmonk's Avatar
07.20.2008, 09:22 AM
Patrick
Thanks for taking the time to explain the process.The equipment links were cool also
Skelbow
Skelbow's Avatar
07.20.2008, 12:35 PM
I just want to say thanks to CC for all the help they have done on this site, keeping everyone informed on what has been going on.
I for one, ordered a MMM directly from them, and they will never hear a peep out of me asking when it will be sent. I know they are working as fast as they can, and constantly bugging them wouldn't help out it get out the door any faster.
Patrick - it is sort of funny, your post about all the machines you use. I work for a company that pretty much uses all the same machines. Stencils, Paste Machines, Pick n Place machines, Reflow ovens, so I do understand everything that you have had to do. And I understand how problems can arise and screw things over so to speak.
-Cory
  Send a message via MSN to Skelbow
E-Traxxer
07.27.2008, 05:58 PM
Patrick
Not enough info.
Need pics.
Monday? Can you please tell me which day of the week that is? Is it after Wednesday?
What's an MMM?
What is the size of the UPS truck that is delivering the stencils?
Hahaha
Thanks for the info, sounds really interesting... and expensive.
