07.20.2008, 03:21 AM
Generally, you toe IN the rear and toe OUT the fronts. And if this was the case, you'd most likely be veering in the same direction.
Also, check the foams in the tires. They can break up over time and get unbalanced. Also check the glue bonding the tire to the rim. It doesn't take much to mess up with tires spinning at high rpms.
