azjc
07.20.2008, 10:12 AM
IT was about 90* outside with 90% humidity, The drivetrain is SMOOTH as butter and gear mesh is perfect, im geared 17/46 for 43mph with 5% loss,esc settings are:
lowest timing
high start power
70%punch control (still WAY TOO fast)
50% brakes (which get used ALOT in the race)
16.5v cutoff
I would try lowering your pinion size, lowering the start power, and instead of using punch control I go into the CC program and adjust the throttle curve, I am not impressed with the punch control
