Desmo
07.19.2008, 10:17 PM
Has anyone looked at a 200mm touring car body to see if it would fit?
they are about the same size as a 1/10 monster truck body
I used a xtm mammoth bumper on my landmax. Its not perfect but it was easy to put on. I planned to add a brace to it but i never got around to it. The old landmax bodies are like gold so you don't want to wreck one.
Like the original pan head hardware and the short arms ?
07.19.2008, 10:19 PM
What tires are those? And do they use 17mm hexes like buggies do?
Desmo
07.19.2008, 10:22 PM
those are the origanal tires and wheels. They use a 19mm hex like some old buggies did.
cemetery gates
07.19.2008, 10:30 PM
Hey Brian, you could use this wheel/tire setup. I think it would look somewhat scale.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHWJ0&P=7
http://www3.towerhobbies.com/cgi-bin...&I=LXKGN3&P=ML
Desmo
07.19.2008, 10:48 PM
Are those wheels standard buggy size?
cemetery gates
07.19.2008, 11:09 PM
I think they are close enough to these in diameter to work.
http://www3.towerhobbies.com/cgi-bin...?&I=LXTTC2&P=7
07.20.2008, 03:06 AM
If you wanted to use slayer wheels and tires, a set of savage or lsp axles should do the trick. Then you can use the hpi 14mm netal hexes, and I am sure that the slayer will use 14mm hexes...unless traxxas goes with the new 17mm stepped hex they put on the revo platinum. I figure that they will stick with 14mm hexes.
The savage axles fit if you are using dogbones on the buggy. You may be able to swap out the cv style axle ends if you are using cv axles on the buggy.
http://www3.towerhobbies.com/cgi-bin...&I=LXDLE5&P=OW
http://www3.towerhobbies.com/cgi-bin...&I=LXDVK2&P=OW
Ofna hyper buggies are nice, but the ofna gtp solid center spool will not fit the hyper bulks, bearing sizes are different... Not sure if there is a solid center option for the hyper buggies.
mriccucci
mriccucci's Avatar
07.20.2008, 08:18 AM
As far as bumpers go the HPI Savage uses a similar bumper to the one that Desmo posted. Link to the bumper here
07.20.2008, 08:20 AM
Standard 14mm from pic
brushlessboy16
brushlessboy16's Avatar
07.20.2008, 02:59 PM
Hey brian, any interest in my raze im trying to let it go cheap
The Jang beat you to this one except his power system was... uhm, lacking
12 cells (nimh) and a novak maxx system...yuck
http://ultimaterc.com/forums/showthread.php?t=92965
http://www.ultimaterc.com/projects/project-21/
skellyo
skellyo's Avatar
07.20.2008, 07:44 PM
Brian...sent you a couple of PM's and haven't heard back from you. Just want to make sure they're making it to you.
07.20.2008, 09:30 PM
Oops. I turned off PM notification, and I sometimes forget to check them... Reply coming in a few...
skellyo
skellyo's Avatar
07.21.2008, 09:45 AM
Ygpm
TexasSP
Something, anything, nothing
TexasSP's Avatar
07.21.2008, 10:49 AM
Brian, found this for you on the TRX forums and thought you would like it. Nice little corr conversion along your lines.
http://www.youtube.com/watch?v=ITn10JRmGe8
Edit: didn't see brushless boys post. Oh well I will leave this link anyway.
www.cubicle101.com
07.21.2008, 10:53 AM
lol, I was just looking at that.
I just picked up a Mugen MBX5 roller from Skellyo as the base for this project. Hopefully the mailman will show up by Friday so I can "prettify" it over the weekend.
