Settings?
ilpufxit
ilpufxit's Avatar
Settings? - 08.01.2008, 11:25 AM
What are the settings on your MM? Is it the same ESC you're using in both vehicles? Set reverse power to 100% and see if that helps, I had a MM running backwards, set to 50% once and it took me a while to figure it out. I don't really understand the short runtimes though.
Originally Posted by mxracer View Post
i have 2 brand new truggies , no binding , everything smooth as silk
got 7 x 4s flight power 4900 packs (so that rules out a dud pack)
1 truggy is MM 1515 1Y geared 13/52 motor temp 50deg C
other truggy MM 1512 2.5d geared 14/52 motor temp 70 deg C
both get 10 mins runtime
then i tried the 1512 2.5d on 5s with 12/52 and still 10 mins . with no extra speed and motor temp 70 deg C
