08.11.2008, 10:11 AM
Originally Posted by FG101C View Post
Yes it is possible to lose the battery. When my V1 went up in smoke the wires from the battery lead to the esc board came unsoldered, had they shorted out in the chassis or together then the battery would have went up.
Thanks.
That wouldnt be the esc killing the batts directly though would it, that would be the ends of the wires touching and shorting, but the odds of them staying jammed together like that for more than a split-second are pretty slim.
As for the escs durabilty- just stick a zip tie around the case and that stops it from coming apart (as I found out). Mount it low as possible on the vehicle and you'll be fine.
FG101C
08.11.2008, 09:20 PM
The ESC melted down into a stinky pile of plastic.
I should know better than to post on forums.
