BlackedOutREVO
08.16.2008, 02:14 AM
About dang time you get here Mike!
Neu 1515 1.5Y
6s flight power
MMM
EDIT, figured it out
heres what I say
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 14
Total Voltage: 22.2
Motor KV: 1500
Tire Diameter (inches): 5.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.011
Spur/Pinion Ratio: 3.64 : 1
Total Ratio: 12.04945 : 1
Tire Circumference (inches): 17.59 inches (446.86 mm)
Total Motor Speed: 33300 RPM
Vehicle Speed: 46.04 mph (73.96 km/h)
Estimated Adjusted Speed: 43 mph (69 km/h) - 6% loss
Effective KV Value: 1500
KT constant: 0.9 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
