brushlessboy16
brushlessboy16's Avatar
08.19.2008, 08:04 PM
hmm can anyone pop the case of one of the v2's and see if the issue has been adressed?
jhautz
jhautz's Avatar
08.19.2008, 08:13 PM
which issue?
I have already popped the case. The only thing I can see different inside is the padding added under the board that apparently is supposed to stop the white fan plug from breaking off of the board. The pad doesnt work. The plugs still break off.
The fans still catch on the case and fry in no time. Now they just wait untill the esc reaches 150 degrees to do it.
The slot in the case where the Rx and switch wires is still too tight and will wear away the insulation. This should be opened up a little and some extrax electrical tape or shrink tube installed.
The only thing that appears to be fixed is the BEC failures. However... That was the big one. The rest of the problems can be fixxed with a dremel.
to make it...
or break it...
Silent...But Deadly
brushlessboy16
08.19.2008, 08:18 PM
which issue?
someone needs to make a How-To for MMM durability mods, full pics and instructions.... id vote it to be a sticky too
tc3_racer_001
tc3_racer_001's Avatar
08.19.2008, 08:21 PM
and a how to mod it within warranty. :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
