e-mikey
08.23.2008, 09:45 AM
Will the motor mount in Mikes store fit a 8.5? I know it's to the side, but it seems like the only quick way to make this happen.
tc3_racer_001
tc3_racer_001's Avatar
08.23.2008, 07:18 PM
see my thread in the buggy forum. :) (it does with some parts from the h8 diff)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
e-mikey
08.24.2008, 12:42 PM
Okay, this is my first time using calipers, not sure if it's right...
for the mount holes I have 34.70 front to back, 21.15 side to side, 40.74 criss cross.
could i get measurements of the center-to-center distance of the center diff mount holes (where it attaches to the chassis)
also the distancece between the inside of the front and rear center diff mounts
brushlessboy16
brushlessboy16's Avatar
08.24.2008, 01:08 PM
hmmm 34.7? and 21.25. were your calipers zeroed? kind of odd
e-mikey
08.24.2008, 01:18 PM
Should they all be like 35.5 and 21.25, or should they all be whole number?
brushlessboy16
i would expect a hole number or half, quarter etc.. just not .4 :D
08.24.2008, 01:21 PM
Easier to measure the outside and inside of the holes and then split the difference rather than guessing the middle... :)
brushlessboy16
08.24.2008, 01:25 PM
chris you have a hyperst, you can measure it ;)
e-mikey
08.24.2008, 10:40 PM
What parts should I order?
08.24.2008, 10:53 PM
I don't have calipers - sorry
08.26.2008, 11:00 AM
I've got a Hyper ST and calipers, just let me know how you want me to measure them, I'd be happy to.
08.26.2008, 11:03 AM
From the bottom the top and bottom of the car we need the inside and outside measurements of the diff mount screws - length and width
Also height of diff mount - inc and excluding stiffner plate
Also height from bottom of diff mount to bearing and from bearing to top of diff mount.
brushlessboy16
08.26.2008, 11:04 AM
the center to center holes, lengthwise and width please :D
tom255
tom255's Avatar
08.26.2008, 02:42 PM
Its not just so simple, take measures and draw, cut detail. They need generate G-code check that G-code and then try to mill. Actualy best to give whole car to specialist and explain that you need
08.26.2008, 02:49 PM
If this goes ahead I'm happy to lend my car to mike but he already has a hyper mount so I believe will be able to do this simply by adjusting his existing design...
