08.25.2008, 01:14 AM
That setup should be fine.
What is your ESC settings? Make sure the timming is set to 0
Also, what diff fluid are you running? If it is still the standard diff fluid you will need to get thicker fluid. I run 5000 - 10000 - 3000 but most others run thicker. I also have that motor in my 8ight but am running 5S with 13T pinion and 46t spur and my temps for the motor are around the 160F mark adn 115F with the MMM. What spur are you using since you are running 48t?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
